automatic shifting point
1970 lemans stock I was out driving and stopped at red light when it changed I put it to the floor and although I wasn't looking at tach it shifted before 3k never really got to rev up, is there a way to adjust it so when I step on it it gets up? if I was trying to pass a car it would have been embarrassing, shouldn't have to shift it myself.
Presumably, this is a new behavior. I would suggest that your vacuum modulator either has a leaky line to it or you might need a new modulator. I'm guessing that its a TH350 transmission. Have you checked trans fluid levels?
level is good i'll check the vacuum line next thanks
only had car a few months first time i got on it, i have found a few things the previous owner mech did ,vacuum line to distributor was at wrong port and adjusted carb wrong,also put on wrong fan for cooling the radiator if he put in amp for radio did that wrong too.
