Proportion valve
Am i correct (?) in my thinking that i can simply delete the distribution box in my 69 and plumb in the proportion valve that mounts under my master cyclinder?  The pv does have a brake signal, and the Master IS a duel chamber. Thanks for any replies😎
bit more info needed Derslkayer1...
proportioning valves are needed when you convert your brake system to disc front drum rear, in that case you certainly loose the block under the master cylinder and you will have 3 ports to pipe you brakes too on the new master/proportioning valve.
 but please note! it needs to be the correct one to suit your master cylinder bore and slave cylinder sizes
