factory radio
Yes it should. OEM radios are typically produced by Delco Electronics or Bose. Let's hope that the stock wiring is still in good shape and that it was not cut up in order to install the Pioneer unit.
  • 4 weeks later...
all their not cut up even has box to keep the annoying chime when door open with key in
So which radio did you decide to get? Have you gotten it yet? Is it installed?
getting new rotors/brakes and trans cooler then will work on radio
That's important too!
