360Rocket's 1970 GTO
2019 March
  • Welcome to Forever Pontiac
  • 1
70Goat
Brackets for alternator and power steering pump
Question
Good afternoon all-this is my first post here :).  I have a 1970 GTO that is getting a 455 installed ('73 block casted in October 1972 with 6X heads).  What alternator and power steering brackets do I need?  I know the brackets have to be the same year but any advice?  Thanks.
2 answers to this question
  • 0
Welcome to the board.
Just to start with you would need at least items/parts 1-9 off this list from Ames Performance.
https://secure.amesperf.com/qilan/Search_Web;jsessionid=BB95EECA2900C8A18BCA2710BB4497F4?order_number_e=MzE3NDEyMQ%3D%3D &method_1=&method_2=&on=Y&search_method=3&cat_rowid=1&search_year=1970&cat_sec_rowid=12&cat_sec_sub_rowid=1189&sort=0
And you are correct most issues come about when you try to mix & match.
Best of luck
  • 0
Hi there, when I had the alternator replaced, the bracket came as an option to it. I ordered mine online, it was an aftermarket piece (https://www.carid.com/alternators/), and there was a dropdown menu allowing to pick the options. So there I selected the bracket. Must say, it was slightly different from the OE one I had originally, though it still worked fine. That was my solution.
Join the conversation
Answer this question...
  Only 75 emoji are allowed.
  • Featured Topics
  • Similar Content
    • By G118
      I'm new to the forum and also to the build world.  Just want some good respectful, opinions, and ideas, how how to build my 73 grand prix 455. First like to start with what size carb and flowmasters?
    • By dahlby73
      FOR SALE: 1973 GTO Sports Coupe one of 519 made with the 455 CI motor with automatic transmission. California car. All original number matching drivetrain. Motor turns over but 2 cylinders only have 5 pounds compression. Not running. Have original build sheet that was found in the car. Well optioned. Clear Minnesota title. Asking $5000. Make offer. No scammers please. Cash upon inspection of the car. Located 25 miles south of Minneapolis, MN. Call or text 612-599-1641.
    • By Bruce
      HI I have a 455 that I need more info on the heads are number 15 and the block is 0147946yh. any info on what I have and a value Thank You
    • By sinister.poet
      Hey I have come across a '76 Trans AM I am going to "restore" I'm not completely worried about keeping it original although I am keeping any original parts I would replace; heads, cams, etc....
      Well I have the original 455 engine I need to have some work done on it, and I want to beef it up some as I know in '76 it took a huge power dive to about a 200hp engine. I was wondering if anyone had any ideas or information on what kind of upgrades I could get on the engine (like aluminum heads possibly, or a better cam) and what kind of compression ratio I should get it set to. I'm under the idea that the original compression ratio is 7.6:1 which is pretty low, so what might be an ideal compression ratio? If anyone has any information that would be helpful to me that would be great.
      Thanks
      Nick
    • By 73ventura
      i've had a 73 ventura with a 350 sitting in the shop a couple of years and today i bought a 455 from a 70 Bonneville. everything shows this YH block to be the 360 hp rated engine with 2 bolt main and it has the #15 heads. I have a set of 6x-8 heads from a 77 400 and wondered how low the compression is going to go if i run those heads. The 6x have the 2.11 valves with dual springs and i think they will flow better, but i would like to keep this 455 pushing 400 HP. I haven't decided on a cam yet until if find more info on which heads to run
