ga owners help !!!!!!!!
engrish please?
well u dont have a ga so it dont matter lol
common sense the air idle valve .... if its going out would it cause bad acceleration ?
better
lol
well i would think people who work on cars dont HAVE to have your exact car to help figure out your problem. do you only take your car to a mechanic who HAS a GA?
and it depends, how much acceleration can one get in their driveway?
lol anyway, a bad idle valve usually effects the idle. hesitation and horrible accel is usually spark problems
(thats in general, not just your engine)
and "common sense the air valve" isnt a sentence either. work on that engrish
you might have to give us more info than "bad accel". is it low end accel? is it top end? is it both? when it bogs down is it getting too much fuel, or too much air?
I use to have a car that would idle ruff and have a hard time shifting into 3 & 4 gear. It turned out to be a loose spark plug wire, for some odd reason it would rattle loose or even fall off. (the spark plug end)
well according to mr .mechanic (kaymo) than it has to be a fuel problem . because when i go to floor it , it just seems its no getting all the fuel it should or some thing . and for that exact reason i only take my car to the grand am mechanic where i live , because he knows what i mean when i just tell him
Hrmmmm...
The IACV won't affect acceleration.
It's either of three things here,
1: Bad spark. Plugs and wires could be done, replace with a quality aftermarket or OEM wires. Stick with the AC Delco Iridium plugs since you have the LA1 motor. Anything else, the motor will run like crap.
2: Bad fuel delivery/pressure. Replace the fuel filter, which is easy. It's in between the rear suspension and the tank. Also, the fuel pressure regulator is a possibilty, but you'd have a vacuum leak also.
3: Bad catalytic converter. My GA did this at 82K. Bad acceleration, bad gas mileage. Replace with a direct fit OEM style. Autozone carries the Magnaflow direct fit, $165. I have the same one with zero issues.
What's the mileage on the GA? Also, has a tune up been done? SES light at all?
' date='Apr 2 2010, 01:39 PM' post='19719']
Hrmmmm...
no lights or anything it could be spark plugs thats all i can think off
ok i forgot to ask, when you floor it and you get the bog, it could be from too much or too little fuel. if its too much, it would dump it out the back and you would smell rich exhaust. bad spark would allow unburnt fuel to dump out the back as well. do you smell gas in the exhaust?
no you cant smell it i try spark plugs
if you dont smell gas, then check all your vacuum lines. are those cars MAF or MAP? i havent looked at many grandams. if its MAF check your intake piping for leaks
hey i just realized how close grandam and grandma is.....
HAHA awesome
If your idle air control valve (which is common in many cars, btw) went bad, your problem wouldn't be hesitation. But I agree with Chaos, plugs and wires would be a good starting point. Then move on to fuel.
Are you always this much of a Jack-mo to people who help you?
it seems that if you dont like the answer or statement to somethign you post you like to be a dick... Maybe you shouldnt ask the Whole board in a thread a question.... you should try PMing people who have grandams if you want to know their opinion only
