possible pcm problems help!!
i have a tech question for ya, about 2weeks ago i lost third gear. I dropped the pan and everything was clean no metal shavings fluid looked new. Now today after work I started my car and my DIC said "service abs, no traction control, no stability control, and no steering assist. I took it to Orilleys to have them scan the pcm. It said tcm read error, bcm read error, speed sensor error,and some others things. I get the feeling that my pcm is bad. It is a 04 grand prix gtp comp g with 75k miles. What are your thoughts folks. Thank you
My first thought would be to check your speed sensors and brake booster module and harnesses for moisture and/or corrision. Drying them out and applying some di-electric grease might help. Those would things certain impact the ABS/Stablitrak/traction control systems. Using compressed air to blow out any dirt from the connections is a good thing. You may have a faulty speed sensor on one of the wheels that may need replacing too. These Grand Prixes have had issues with this in the past.
A poor or faulty ground is another possibity, but those can be a devil trying to find too. So check each wheel well, the brake booster, and ECM in the engine compartment for any loose, broken, or missing wires and connections.
  • 3 weeks later...
Thank you frosty.  I did indeed unplug the the harness and cleaned them out and now it is intermintent, so i think the sensors may be loose or possibly bad.
Also i ended up buying a new pcm from Will at Overkill and i must say I freaking love it.  The throttle response in amazing, engine stays much cooler,  a much better ride overall.  I definetly recomend this pcm.
