POTM Nominations, February 2015
All members with 10 or more posts may nominate their own Pontiac and/or another Forever Pontiac member. Anyone can nominate another member!
Please post the important and required details of the one you are nominating, like: Photo, Screen Name, Year, Make. Model. Modifications or Progression Link - link would greatly help but is not required.
Please submit only ONE photo in your post.
You may NOT submit your car, only someone else's. One submission per person.
***For a LIMITED TIME OFFER, you may submit your car! If you meet the 10 post minimum and other requirements.
If there are more than 10 submissions then the Nominations will close and only the first 10 submissions will be in the Vote. If a tie occurs, then there will be a 2 day tie breaker vote. In the event that it is still a tie after the tie breaker, the car nominated first will be declared the winner.
There is also no need to submit the same car more than once!
Off topic comments will be deleted. This is a nomination only.
Any member that has won within the last 6 months is ineligible for nomination, unless the member has another vehicle that meets the requirements may be nominated again.
It is assumed that you, the member, has ownership of the vehicle before, during and after the nomination and voting.
Nominations ONLY! This thread will be monitored.
Banter will be encouraged in the POTM Banter thread, and not allowed here.
Winners get their photo at the top of the site.
Winners getting rid of their vehicle after they have won may be subjected to disqualification of their POTM Status.
Recommendations only please!
'04 Supercharged CompG with complete FBSS Airbag suspension
Air Setup:
-5Gallon Stainless tank,
-2 480 compressors,
-3/8" airlines
-5button controller,
-8 1/2" valves,
-SMC water trap
-SMC check valves
-200 amp relay
-110/150psi switch
-Zenith digital tank psi gauge
-Dual Double needle bag psi gauges
Interior:
-Custom Interior with red carbon fiber seat and door inserts
-AeroForce gauge
-AEM Wideband
-JVC NSX1Double DIN
-2014 camaro rearview mirror
-Rear center Alpine speaker
-LED Interior - complete
-Viper Remote start /alarm
Exterior
-Inferno Lip
-GXP Rear Bumper
-Retrofit Morimoto Square D2S BiXenon Projector Headlights
-LED Fog lights
-LED Taillights
-LED Blinker Retrofit in Highbeams
-Custom made Roof rails
-Carbon fiber pontiac emblem overlay
-08 Impala SS Front Brake/Rotor upgrade
-18" American Racing Palmettos on Bridgestone Potenza RE970as 245/45 Tires.
Engine:
SLP 1.8Roller_Rockers
TOG Headers
ZZP TOG DP
Resonator Delete
3.6 MPS
10.5mm ZZP wires
EGR Delete
Killerglass Radiator Hose
Engine Bay Wire Tuck
90# LS6 Springs
Autolite 104s
Viton Seals
Modified LIM
TEP ShiftKit/DEX6
External Trans Cooler
HPTuners Pro
GM STB Front&Rear
Chrome Billet Valve covers
:Updated:
This car is daily driven.
Mod List
Exterior:
SD Lip, Blazer fog lights, 40 candle power reverse lights, Spyder Projector headlights with 6000k HIDs, Spyder LED taillights, Custom Vented hood. Plate Filler. 1 year (2003) only GTP badge, Reflective White Pontiac Decal.
Interior:
6000k LED light swap, Full red LED driver information center swap, 5 red LEDs in cluster, 19" LED strip trunk light, heated seat.
Engine:
Option Racing ram air intake, ZZPerformance, 10.5mm wires, Auto-lite 104s, ZZPerformance Strut tower bar, ZZPerformance Polished dog bones, ZZPerformance polished valve covers, ZZPerformance billet oil cap, Custom Tuned PCM, 04+ coolant bottle swap, Meziere Electric water pump.
Transmission:
Rebuilt, ZZPerformance 2500 stall Torque Converter, Trasher Stage 3 shift kit, ZZPerformance Stage 1 Axles.
Exhaust:
ZZPerformance Powerlog, ZZPerformance 3" downpipe with high flow cat, ZZPerformance 3" Cat back exhaust system.
Suspension:
GMPP Rear Sway Bar, Dorman Solid Sway bar.
Wheels:
2005 Ford Mustang rims
Bridgestone Pontenza 225/60R16
E49BE081-F3F5-40AB-8A4C-BAF1794AE0E7_zps
I am going to nominate our son's 1984 Firebird S/E. We bought this for him about 4yrs ago and since then he has done on his own tons of work on it, especially the interior. We also had it re-painted for him, and the car looks fantastic. This is also his daily driver! I do believe he is a member here too.
I know many do not like the 3rd generations of Firebirds, but as far as we look at it, any bird is worth saving. :rolleyes:
