Pedja's 1968 Firebird
2019 March
  • Welcome to Forever Pontiac
  • 0
Squall21
Over Heating
Question
My coolant level drops after a week, and when sitting in traffic it almost over heats until I move again. No idea if its leaking somewhere or evaporating. Also no heat in the winter and smell coolant when fan on.
5 answers to this question
  • 0
I'd suspect the pressurized coolant cap first. If it's loose or doesn't seal well then you might get symptoms like you described. A new cap should be under $10 and any local parts store. After that, I'd look into replacing the thermostat and checking your coolant reservoir for any signs of oil mixing in.
  • 0
You may have a small leak in the heater core. The fluid would collect up and then drain through the A/C drain onto the ground. You may only see this when the vehicle is running. Top up the fluid and run the car up to temperature. Have a good look throughout the motor. Put a piece of cardboard under the car if you cannot find anything. This may take a good 20 minutes or so just be patient.
  • 0
Can I do the thermostat myself or do I need to see my local mechanic, also already changed the coolant cap already cause it wasn't sealing properly.
  • 0
You should be able to do it on your own. Look it up on Google for your make model and year. Or in a Chilton manual if you can get your hands on the one for your model yr. Some libraries have them.
  • 0
Sounds like thermostat issues i had the same prob with my ga.
Join the conversation
Answer this question...
  Only 75 emoji are allowed.
