gscherer78ta's 1978 Trans Am
2019 February
  • Welcome to Forever Pontiac
Ringo64
[Unconfirmed] 6th Gen Camaro Engine options
From GMI:
2.0L Turbocharged I-4
3.6L LGX V6
6.2L LT1 V8
6.2L Supercharged LT4 V8
http://www.gminsidenews.com/forums/f...ine-up-170233/
Am not too thrilled about an I4 being added to the lineup, being a pony car and all but I guess there needs to be some competition with Ford and bring up CAFE mpg fleet sales... Need to see what power it will have and how much the new gen Camaro will weigh.
Agreed. You forgot to ask how much it will cost too. If the turbo I-4 cost the same as LGX 3.6L or more, then somebody in sales and marketting has a serious case of cranial - rectal inversion.
So GM wants to fight Ford with a turbo 4 pony car of their own...
If GM puts a I-4 or turbo I-4 in a Camaro, they should call it a Vega instead.
interesting...
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
  • Featured Topics
  • Similar Content
    • By Ringo64
      Always interesting:
    • By steveeoaktree
      Well fellas, I will finally have some more time Saturday to get to tweaking the issues with the '76 GP's idle/accel issues. Started with running terrible and popping back through the carb. After a new fuel pump (smelled fuel in the oil), wix inline filter and new lines, and 2 Rochester carb rebuilds (soaked the parts overnight in the carb solvent the 2nd time as well as installing a new brass float), re gapped the new plugs to .045 that were gapped at .080 by the seller, new vaccum lines, and I also have the new pcv valve and lines (there wasn't one) to install Sat. It now accelerates MUCH better, but idles like it wants to die at stoplights (and does die sometimes) but starts right back up. I thought maybe to tweak the vaccum lines to see how they work best b/c some diagrams show a "t" going to the vac advance with one going to the manifold, and the other going to the carb... and some diagrams just show a single line to the carb. I also don't know it the missing pcv would cause any minor idling or accelerating issues, but I do know that it should be there. the timing is solid. I am going to drain the tank again and refill it with 89 octane fuel to also see if that helps. I am curious though, as it seems to only try to die after it's warmed up. I know there is a choke internal in the intake but it's tough to find a diagram specific enough to list all of the line connections for a 1976 400 2bbl... (most show them for the 4 bbl) If any of y'all have any tips, I'll surely give them a try either tomorrow after work, or Saturday when I do the rest... Have interior pieces to dye inbetween as well so it should be a great Poncho day -- just would feel much better if I could get this baby to run smooth! She's sooo close...
      Thank y'all  for your time, and all of the guidance that you've given.
      Stevee
    • By djholzenkamp906241
      Just looking for input on what I should do to build a new motor for my 1968 GTO. I have a spare 400 block bored .060 over and was looking at a stroker kit from butler performance this will be my first engine build from the ground up would like to get 500+ hp....and any ideas on different heads? What combo works the best? Intake?Cam?
    • By Ringo64
      Some photos of the 6th gen Camaro going around the Nurburgring. Not sure if I'm liking what I'm seeing:
    • By Ringo64
      I don't know if it is all the body cladding to protect it's design but it looks very stout/short. Interesting none-the-less!
