Rayz571's 1977 Can Am
2020 June
  • 0
mack
2001 Grand am
Question
Driving down the highway I saw lots of smoke coming out of my engine bay, when i pulled over and looked under the hood i had oil on the driver side just behind the power steering pump pretty much every where, i took some to look for a possible leak cause and was unable to find any immediate problems, but there is a lot of oil, no noise accompanied the oil leak, any ideas or experiance on what the problem could be? an extra note the power steering pump and sealing surface aria is clean i just dont know if its an oil line, valve cover, or head gasket or mabey something i missed completly
13 answers to this question
  • 0
Are we talking 4 or 6 cylinder here? Either way, if you have that much oil all over, the leak should be fairly obvious. Try looking while the engine is running but I'd be very careful about driving it very far until you find the leak. Maybe top off the oil even before starting it to ensure you aren't too low to begin with.
  • 0
Clean the oil. Start your car in the driveway and just look under the hood. See if you can spot the location.
  • 0
Letting us know if it's a four or six cylinder is going to help out immensely. I know the V6 wasn't known for oil leaks like that.
Also, pictures will really help us figure out where the leak could be as well.
  • 0
Wasn't the 01 SE available with just the I4?
  • 0
v6 was always available on SE's. I actually think 05 was only v6's....
  • 0
Ahh, I wasn't sure. I don't know much about anything but the x-bodies.
  • 0
:slap: How dare you know nothing about a platform you don't own :P
  • 0
SE's could have either or.
The SE was available with the L61 or LA1 even in 2005. I know the SE coupe was dropped after 2002, so finding L61 SE coupe (2002 only) is quite the nice find.
But anyway, OP let us know what engine it has.
  • 0
2.4L inline 4. and i did find the leak, the oil pressure switch was leaking by the electrical component, lost almost 3 qt of oil. but it was an easy fix, only had to take off the plenum to get to it, it took more time to get the car to where i was going to work on it and do all the running around than it took to repair it
  • 0
8 bucks for sensor, and 1 oil change all is good and in working order
  • 0
Excellent, good to hear you found it
  • 0
I had a feeling it was an oil pressure switch. I forgot with the LD9 it's more up top. I'm used to imports with it being in the oil pan...wait, mine was in the oil pan though.
Oh GM.
