Jakeman's Jeep Comanche
Other Work done
4WD AX-15 Trans and TC
31's
D30 Front Axle
Its started out as a 2WD when I got it. My spindle went bad bc of the bad wheel bearing so I got a D30 front axle and Started the 4WD conversion. I had some trans/clutch problems so I got a AX-15 5-speed trans and a Np231 TC. It had some major wiring problems mainly worked out now. Clutch is fairly new. All new drive shafts. New valve cover gasket. New clutch Master Cylinder and Slave Valve. Had some thermostat problems(still have). but long story short thats the details on my Comanche
I counted maybe 3 or 4, maybe 5 different brands and tread designs of tires in those pics. Keep in mind with 4WD you need to keep the same tread type all the way around, otherwise it will wreak havoc.
They are all the same
Bf All-Terain T/A
