Okay I may actually do this to my winter wheels.
I do have some questions tho.
1. Since the paint is flaking off my wheels should I take the whole wheel down to bare aluminum?
2. Should I prime the bare aluminum?
3. Does this stuff fill imperfections fairly well?
  • Replies 27
At a minimum, I would clean them down to fresh metal so that the flaking materials is removed. I would clean the wheels with wax & grease remover and/or acetone. No need to prime them - just paint over them.
If you were going to paint them with regular paint, then you should scuff them with a scotch brite pad,clean them, use an etching primer for aluminium, and then paint and clear coat. Plasti-Dip won't need this much prep, but it is not as permanent as regular paint either.
I have no idea how well it fills in imperfections. I would suggest using several light coats and intentionally over spray it onto the rubber wheels. You can paint the edges and then peel off the excess of the tires only.
