Lincoln Electric Plasma P20
http://www.sears.ca/product/lincoln-electr...0887166-K2820-1
These went on clearance at Home Depot about a year ago so I picked one up. Good little unit for cutting out body panels and some light frame work but I would not want to use it for 3/8" steel all day. Since I bought this I have almost all stopped the use of my grinder for cutting out body steel. So far I love to use it but it does have its limitations. I have found the electrodes do get burned up quit quick but some of the work I do is not the cleanest. This does nice precise cuts with very little clean up.
When it went on clearance it was sold for $650.00 so I picked it up. Thanks Pro I will see about adding an extra air dryer to the system see if that helps. I went through 2 in the trunk of the Chevelle but at $10.00 for four maybe I should not complain about cost.
I am officially jealous! Bad enough that I have to goto DK's with Tim Horton's Timbits in my hand to borrow his TIG or his soda blaster. Dang, I need to get some more expensive toys.
Well you may have to come over to use it. I will add 8 ounces of water to 12 ounce can of Molson Canadian and it will be like drinking Budweiser.
