Ghost's Progression
car may be in safe mode which isent good at all, that means off to the dealer you go. I hope not but if its doing stuff like that you should get it looked at asap before you break something else and it costs you more money!
  • Replies 294
aw i gotta try that! so far i have only replaced the second sensor. im doing the fist one tomorrow. so with that cleaning process, do leave the code on and not clear it? and i dont want to go to the dealer. <_<
it should go out by its self.
thanks guys, didnt know that it can be that bad for the car. and thanks for the video! ill do that and also replace the sensor and hopefully that will do.
well i changed out the sensor last night. and as i was doing that, i noticed something. not the sensors or the cat...the problem itself?
I think you found the issue..................
that's kinda crazy it cracked but looks like headers are in your future if that's your issue.
yea use a spray bottle mixed with dish soap, just like you would with a car tire leak. just make sure you do it with the car cold or you could crack it even more. ;)
on a second note, I spy with my little eye something not plugged in. See the little grey and blue wire harness. what's that????
i was ruling out the possibility of it being the sensors so i was changing them. i disconnected that one then took off the heat shield and saw the crack.
tested. no weird sound. i sprayed it, turned on the car on and quickly checked. it was dry so i sprayed while its on and but most of it doesnt even land on it and flows towards the firewall. :picard::(
Is everything ok now?
Im holding my :woot: till I know........ ;)
:lol: i took it on the highway after i left the dealership. i know its no V8 (or V6 for that matter) but i felt the power it once had and heard it. i would have heard it a bit more but i had put on the stock intake.
:lol: All 100 horses? :D jp
Good that she's back!
