  • 0
Remote start won't work
Question
Hello everyone hope you are all doing well, I have a feeling that my key fob battery is dead. But it never hurts to ask. It seems that my car wants to auto start with the key fob but the lights just flash and it doesn't start. Is there anything beyond a dead battery? Or do I have to actually chase some wires or settings down? Thanks in advance
Edited by TheWizX
9 answers to this question
  • 0
Is the car locked prior to attempting remote start on the fob? Know with GM cars the car has to be locked before the remote start will work.
Otherwise, the car is starting normally when you attempt it with a key in the ignition?
  • 0
Yeah it's locked before I try. Every.. 5 starts or so the car won't start the first time but I give it another go and it starts right up
  • 0
Step back snowman.......Ringo's got this one!:clapping:
  • Haha 1
  • Confused 1
  • 0
2 minutes ago, Last Indian said:
It is possibly the car battery voltage. New cars really need at least 12.25 or higher! The other issue that goes with that is a load test! That’s when a bad battery that shows 12.25 or higher, but when you try to start the car the voltage drops below 9.6v and actually below 10v can be suspect depending on several other factors.
My onboard computer reads 14v but you never know. I'm going to check oil and coolant and replace my fob battery. I've heard that if your fluids aren't within a certain parameter, remote start won't work
  • 0
That 14v is when the cars running! Which is what the alternator voltage is sending to the battery. Which has nothing to do with the battery condition!
No! Fluids will not effect the remote start!
  • 0
3 minutes ago, TheWizX said:
I work at an auto parts store so I will do a test on the battery and alternator and get back to you
Just remember it could be that, but it could be something else too! In the end it’s an electrical interface that’s the issue. Something tells something else to flow electrical energy to the starter and bypass the ignition switch! Within that entire circuit somewhere lies the problem. Battery, key fob, switch, DIC menu, etc.
  • 0
Yeah, I can tell it wants to start because I can hear a click and the lights flash but nothing happens.. I'll do some digging. Thank you for the info
