So I’m building out this82 firebird for the strip. In order to get to the ignition wires on the column do have to take apart the column ? Because I’ve taken apart every wire harness that’s under there.
Yes putting in a push start, with a toggle switch cluster to control a variety of things but mostly it has all my stuff linked to a kill switch. I don’t need 30 people telling me I’m doing it wrong bc it’s not stock. Just asking for help
The ignition switch is located on top of the steering column at the bottom toward the floor...and is activated by the locking rod coming down from the key /lock cylinder..Might have to drop the steering column down to access it... The only wires that run inside the column up toward the steering wheel key/lock cylinder would be for the key buzzer ,horn and the turn signals...All the power wires for the starting system will be plugged in at that switch at the bottom.....
