Rayz571's 1977 Can Am
2020 June
I an thinking one of the front wheel bearings however I'm having trouble find it. Symptoms are when sitting still turning the wheels the low traction light comes on. No other lights ie ABS. I know the normal things to check. The plug on the speed sensors. The bearings seem fine I don't hear the humming or tire noises at speed. If I Jack car up there is no play any direction nor do I feel any grabbing feeling or drying out sounds in the wheel hub. Any other way to check them
In theory, the low traction light comes on when the ECM/BCM detects a difference in wheel speeds. Since you said you are not moving, this leads me to believe that you probably have a bad wheel speed sensor and/or hub. I would suggest checking the sensors themselves and perhaps replacing one or more of them.
  • Thanks 1
What Frosty says is accurate, & usually the problem as you won’t see an ABS light unless you hit the brakes hard enough to activate the ABS manifold. If you have or can get an OBDii tool it will tell you which wheel is the culprit.
Put the car up in the air and put her in drive lol. Funny thing is one tire spun and other didnt. It cool to see I differential in action. ( wish it was limited slip) . But to the point found the bearing. It wobbles. Not side to side but rather up and down. How you all figure that is?
Yes at 72 n up there is a deep bass noise that sounds like a hub when str8.  I did say both wheels where in the air???? I check bearing by hand and it did seem to have play. Idk two lane other then this. There might be a small flat spot but I can feel it in car. The low track light pops on when turn sitting still
Edited by Lynn5907
