Pedja's 1968 Firebird
2019 March
  • Welcome to Forever Pontiac
Question
I have a 2000 pontiac grand am 3.4 liter i recently changed my front breaks and i understand new pads smell a little but i drove it on the freeway and at one point i had to push break pedal all ths down to stop what did i do wrong? Also it kind of overheats temp goes 3 notches above normal temp but never fully overheats once i start moving it cools down just want to fix small issue before it gets worse any advice would be great. One more where are the other spark plugs only 3 are visible in front and how do i get to them?
1 answer to this question
  • 0
Check your brake fluid reservoir and see if its low. If so add fluid. You may need to "bleed" your brakes as well.
Check all four corners and make sure your individual wheel cylinders or brake lines are not leaking.
As for your overheating issue, it could be old/bad anti-freeze and perhaps you need to do a flush and fill with new correct antifreeze/water mixture. Your thermostat could be sticking and needs to be replaced. I'd start with those rather simple things first.
The other three spark plug wires are up close to the firewall. Check out this YouTube video to give you idea of how to do it.
Join the conversation
Answer this question...
  Only 75 emoji are allowed.
  • Featured Topics
  • Similar Content
    • By Kenny556
      Hey I’m new here, looking for front rotors on my Catalina. It came factory with disk front and will eventually need rotors for it and can’t find any anywhere. Down the road I want to upgrade the suspension but can’t find anything there either. Ultimately I want it to be a fun boat to cruise in with some power I can take down the strip occasionally
    • By dana
      Hello, our 16 year old found a 1980 Phoenix that had less than 80k miles on it for less than a grand so she bought it. After a water pump, pads, calipers and rotors we still cant get the drivers side caliper to retract.
      The passenger side is fine.  When the car is on stands and in drive the rotors are turning true, no wobbling, which is hopefully telling me the hub is running straight.
      When the brakes are applied the drivers side caliper, which is brand-new, wont retract back unless I open the bleeder valve. When I open the bleeder valve the caliper retracts and the wheel hub starts spinning normally.
      Can anyone please give me some insight on what the problem may be? The caliper is getting plenty of fluid on the bleed but just isn't retracting.
      Thank you,
      Dana
    • By DrJones
      I need help figuring out why my 400 is overheating
      It is a 1987 gen3 Fire-bird Formula (reFormulated) with a 1971 Pontiac 400 block casting #481988 bored .030 over with Keith Black dish pistons, crank has been turned .020/.020. Rotating assembly has been balanced, Number 16 heads with new valves and springs, 72cc cambers. Howard's CAM in.482 ex.470, true dual exhaust, new water pump with cast impeller, divider plate clearance set as close as possible to impeller. New 4 core aluminum radiator with 2 10 inch electric fans pulling air and 2 12 inch electric fans pushing air. A/C condenser removed to allow maximum air flow. Removed thermostat, still overheating. Installed a flow restrictor hoping the water was flowing to fast through the radiator for efficient heat transfer. No still HOT. New 180 degree thermostat. With each change it continued to overheat, although the time it takes to overheat varied. I really hope someone here has an idea what I am facing.
