dues70's 1970 Pontiac Bonneville
2020 July
  • 0
Dre
Power Steering Pressure Line
Question
2008 Pontiac G6 GT The power steering pressure line has a screw between the return line and pressure line. It has a 10mm head on it but the rest of the screw seems to be thicker than other 10mm screws. Any advice? TIA
1 answer to this question
  • 1
Not being familiar with the car, I’ll do my best to answer. I presume it's a double acting clamp with the screw in the middle, this clamps both lines one on each side of the screw? A 10mm head does not mean a 10mm threaded screw. They will use a larger or smaller head screw according to the need and application. Did you need more than that?
