computer parts curiosity
Ghost
how many active computer parts experts do we have? just have a question or two on a thing or two. and just curious to know.
I am dangerous....I project manager server hardware builds all the time. Gaming stations not so much. A buddy of mine is a serious gamer though.
ok so first question: what puts the maximum size limit on RAM? is it the CPU, motherboard, OS or a combination of two or all? if it matters its my laptop and only poking around.
Mainly it is the operating system that is the most limiting factor because it is how much memory that the OS can physically address.
Windows 7 32-bit OS is a max of 4 GB. Windows 7 64-bit varies on the OS version you purchased from Microsoft.
Starter: 8GB
Home Basic: 8GB
Home Premium: 16GB
Professional: 192GB
Enterprise: 192GB
Ultimate: 192GB
Under WIndows 10: for x86 the max is 4GB, for x64 it is 128GB or 2TB. Windows 8 has a 512 GB max limit for x64.
192GB of RAM!? ok next one. of those mentioned, what limits the max speed of RAM?
Let's assume for a moment that you had RAM DIMMs that are rated to 2.4GHz, the same as your motherboard's clock speed. However your CPU processor (itself) is rated at only 1.6Ghz.
It is the combination of CPU and motherboard clock speed which limits RAM DIMM speed. Actual DIMM performance will only go as high as the lower of the two speed limits between the CPU and the motherboard.
So in this example, the CPU runs at 1.6 GHz, and the motherboard supports speeds up to 2.4GHz, but the DIMM's will go up to 1.6Ghz because that is how fast (in this case) the CPU can accept the data from the RAM (thru the motherboard). Conversely, if the motherboard was slower than the CPU, the motherboard's speed would be the limiting factor and the CPU would be waiting for data.
Does that make sense?
  • 3 weeks later...
ok ok. and what is the best way to find out the specific motherboard that is in the laptop? and how can i find out the range of usable CPUs for it? its a Socket G2 i7 and im sure the max 2nd gen is fine. but the 3rd gens also used the G2. i found some better performing (obviously) 3rd gens which also bumps up the RAM size and speed. kinda why i want to find out motherboard specs but also curious on these 3rd gens.
