58Bonne's 1958 Bonneville
2019 June
  • 0
StylinMontana
Coolent flush
Question
How to on 00' montana with 3.4l. I can do it, but whats best way? I would pull drain plug in rad, stick in hose, turn on hose, run engine until fluid out of drain in rad it clear.
thanks :agreed:
2 answers to this question
  • 0
All I do is take the lower rad hose off and let the engine drain for a bit. Then take the upper hose off and run water through it via my garden hose to push most of the remains out of the engine. Re-attach both hoses and fill.
  • 0
I just wanted to add that pulling the lower rad hose is the preferred method.
Some people have had the radiator drain plug leak after it is removed and re-installed later.
Join the conversation
Answer this question...
  Only 75 emoji are allowed.
